Reduced Friction Oil Sumps
TLLB is a lubricated thermal barrier, would hold heat in the pan. Not sure you'd want something like that for long-term, highway use. One of the recommended uses is for drag-race only cars, to help warm oil more quickly.
Originally Posted by OVERKILL
Originally Posted by Shannow
Yes, mine was the hammerhead one...hat's the one that I did my elevated RPM thermocouple down the dipstick tests.
Thought so
Do you know if yours has a windage tray as well? Or is it assumed no, based on that pan design, which probably makes it unnecessary?
Nope no windage tray on the narrow opening...later versions were more open.around the pickup, and I don't think they had a tray either.
The commodores and it's varietals in oz had the sump volume ahead of the fron axle line, in a RWD platform...the sump with wings sitting ahead of the steering rack allowed additional cooling I would say (phase 4 gtho falcons with the Cleveland had winged front sumps back in the 70s)
Being pretty low slung, front sump, they had to make them wide and shallow
The approach here for the Windsor engines was a double-hump pan. I find it quite interesting that you guys took such a dramatically different route.
