Short story is my car started burning oil around 100K. There are absolutely zero drips in the garage - so I'm pretty positive it's burning.
I have scoured the internet looking for cause/resolution for burning oil. The popular opinion seems to be carbon deposits on the piston drain-back holes that prevent proper drainage of fuel/oil. As a result, some oil gets trapped in the combustion chamber and burns up. Some of the inexpensive DIY options that I've felt more comfortable trying include:
I have done 1, 2, and 3 without much change in the amount of oil being burned. I haven't tried #4.
In June I am going on a road trip (3000mi round trip). I was thinking I should take advantage of the extended highway driving to try and clean out the engine. I'm tossing around a few ideas. But this is a rough idea of what I was thinking:
Any thoughts on this? Am I crazy? Is the info I found just bad advice? Vehicle information is below.
Thanks in advance!
2003 Honda Accord V-Tec 4-cyl
> 110,000 mi
5W-20 manufacturer recommended
4-qt capacity
Last several oil changes were with full synthetic (done by me) - before that was dino (done by the stealership)
Typical vehicle usage is 15-30 minute drives - extended driving is very rare
- Add Seafoam to the crankcase & change oil 200-500mi later (mileage depends on who you ask)
- Add Seafoam to the gas tank (on a full tank)
- Replace 1qt of oil with 1qt of transmission fluid in the crankcase & change oil < 1000mi later
- Run Seafoam directly into the vacuum system or air intake
- Next oil change will be with Mobil 1
- Before departure, run 1 can of Seafoam directly into the air intake (per Seafoam instructions)
- On the trip out, add Seafoam to every gas fill-up and add Mobil 1 as needed
- Before making the trip back home, run 1 can of seafoam directly into the air intake (per Seafoam instructions)
- On the trip back, add Seafoam to every gas fill-up and (if oil is still burning) add 1qt of trans fluid
- For the last 200-300mi, add Seafoam to the crankcase (per Seafoam instructions)
- When I return home, do a full oil change with Mobil 1
Thanks in advance!
> 110,000 mi
4-qt capacity
