I like to use Redline Fuel System cleaner once a year on my 2002 Honda S2000, about 1/2 bottle per tank (small fuel tank) once a driving season. This is my favourite fuel cleaning product. They also state that you can run smaller more regular maintenance doses. I'm wondering if the upper cylinder lubricant can cause issues in long term regular use, as Redline has an upper cylinder lube as part of the fuel system cleaner ?.
I once ran Lucas upper cylinder lube and I ended up with fuel dilution issues in my oil, and some high soot count in my used oil analysis. I can't say that the Luca UCL caused the two issues but it happened at the same time. I don't know if there are any side effects of using upper cylinder lube products on each fuel fill.
Should I run Redline fuel system cleaner in smaller regular doses ? or should I be concerned about the upper cylinder lube used long term. If there is some issue with long term regular UCL use then I will just keep the 1/2 bottle once per season treatment routine. Thanks for any replies.
