24' Formula with 1993 motor, Ford 351w HO marine, holley 4160 carb no air filter only flame arrestor, 285hp, Mercruiser Alpha 1 outdrive,
480 total engine hours, less than 50 hours on oil, boat run from early June to late November, Long Island Sound, CT. Also regularly use redline lead substitute, typical operating rpm is 2800-3100 rpm, but I ski with the boat a lot at 3500 rpm.
Dyson Analysis
Results ppm/% (blank = normal)
Wear
Copper 12
Iron 12
Chromium 2
Lead 25 rise is adds in RL up to 10
ppm, may drop with use.
Aluminum 5
Silicon 8 super low, excellent
Tin 1
Additives
Molybdenum 374 depelted due to plating up, ring wear
Sodium 226 add in redline
Magnesium 16
Zinc 784
Potassium 0
Phosphorus 760
Calcium 1850
Physical Properties
Water, fuel, antifreeze all negative
Soot 0 no insolubles, good
Oxidation 40 20% normal, some cleaning going on
Nitration 44 22% normal
Sulfur 40 fuel sulfur
TBN 6 depleted somewhat starts in 10 to 13 range, cleaning and plating
Vis@100 C 13.6 solid 40w
[ January 15, 2003, 07:20 PM: Message edited by: 1 FMF ]
Dyson Analysis
Wear
Copper 12
Iron 12
Chromium 2
Aluminum 5
Tin 1
Additives
Magnesium 16
Zinc 784
Potassium 0
Phosphorus 760
Calcium 1850
Physical Properties
