Just got my second analysis back on this vehicle, engine is turbocharged 2.4 L, driven relatively hard, mixed driving. I also did one road course event on this sample. The previous sample is with a Mobil 1/Redline 10w30 brew, it had one quarter mile day visit on it, so I think the two samples should be similar in terms of engine use. Previous sample used 1 quart Redline with 4 quarts Mobil 1 10w30 visc, posted previously. This sample was 5 quarts Redline 10w-40. Mileage was similar. This sample seen a drop in iron wear but increased aluminum and a bit more copper. Lead is still zero, which I find strange, wonder if there is any lead used in the Chrysler bearings, two samples with zero lead on a turbocharged engine is wild.
First numbers are the Mobil 1/Redline 10w30 Brew
Second numbers are the Redline 10w-40 OCI.
5500 kms on first sample, 5200 kms on second.
Engine has approx. 13,000 kms at time of sample.
Here we go:
Iron - 5 , 3
Chrome- 0 , 0
Moly - 114 , 429
Aluminum-2 , 5
Copper - 1 , 2
Lead - 0 , 0
Tin - 0 , 0
Boron - not tested
Silicon - 12 , 7
Sodium - 9 , 20
Zinc - 784 , 896
Potassium - 1 , 3
Nickel - 0 , 0
Silver - 0 , 0
Soot - 0 , 0
Sulfation - 182 , not tested
Oxidation - 387 , not tested
Nitration 62 , not tested
viscosity, not tested, 12.9 cst
No antifreeze, no fuel dilution, no water in either sample.
Next sample to go in is a Mobil 1/Redline 10w30 brew with 2 quarts Redline and 3 quarts Mobil 1. Right now I am running a full 5 quarts of Mobil 1 10w30. So I should have a good idea of how things are working once I get all the samples together.
This lab is having a hard time analyzing oxidation, nitration as the Redline mix is throwing off their infrareds. They said I should send in virgin samples of the oils being used as they need the information to do a full analysis. I got viscosity readings this time around but not the first sample. Still good information overall. Lab costs are relatively inexpensive so I dont mind.
any questions let me know , thanks.
Joey
Here we go:
Iron - 5 , 3
Chrome- 0 , 0
Moly - 114 , 429
Aluminum-2 , 5
Copper - 1 , 2
Lead - 0 , 0
Tin - 0 , 0
Boron - not tested
Silicon - 12 , 7
Sodium - 9 , 20
Zinc - 784 , 896
Potassium - 1 , 3
Nickel - 0 , 0
Silver - 0 , 0
Soot - 0 , 0
Joey
