My mistake -- I've been jumping around so many threads, I sometimes get mixed up about which idea is coming from where. . .quote:
Originally posted by qship1996:
EKPOLK,re-read my previous posts,this is NOT anywhere near my "first time fill of Redline",as far as insoluables creeping up,after studying many reports here,they seem average at .4,and certainly not out of range to cause this poor TBN retention or viscosity failure to stay in grade-current fill of Mobil 1 10w-30 analysis will tell much for me as to my future use of Redline in this engine.
I understand the resistance to that marketing paradigm that has been sold to folks using synthetics. Oil lubricates, Auto-RX cleans, ask either one to do the others primary job and the chemistry will be stressed. Regardless of brand.quote:
I really have a hard time with having to use any additives with a top tier motor oil.as far as auto-rx,again with this cars frequent oil change intervals,and LIFETIME use of fully synthetic oils,
quote:
Originally posted by Terry:
qship, if its not a problem why not post the earlier raw data to show how the oil wear levels dropped using the current oil brand from the last run.Ah, so there was a trend pattern going on. Virtually all previous comments and speculations are null and void and biases are now exposed.
We do and find RL doesn't perform well, period. People on this board want an oil that shows well in their vehicle.quote:
Guys try to move past the "brand" gig and look at what works in analysis
You shouldn't have to with a good synthetic like Mobil 1 or Amsoil. What I like to do is use Auto-Rx every 15-20k miles and run a bottle of Redline Fuel System cleaner every 10k miles or so. That will keep your engine clean. No reason to doctor up a good oil IMO unless your really trying to EXTEND drains out to 15k + miles. Again, thats my opinion.quote:
quote:
Originally posted by buster:
Again, thats my opinion.Mensch, I'm really glad you said that. I was thinking you were a chemist.
For some reason Qship seems to be stuck on 10w30 Mobil1 or Redline and OEM filters.quote:
I think M1 0w-40/Amsoil 5w-40 would be two great choices year round.
And I thought you'd have something worth while to say.quote:
Agree, it's not about brand but finding the right oil that works best in your car which could one of many and one of many viscosities.quote:
I believe that different filters and weights of oils should be tried especially if UOAs are going to be used for comparisons.
As I stated above, I'm neither a RL user, nor am I planning on becoming one anytime soon. With that in mind, maybe this is just good oil. It's supposed to be a high-performance, long-life oil, so would it not be natural to suspect that indications of problems that arise before the oil should have worn our are caused by something else? I have not done a detailed screening of RL UOAs, but my impression is that the vast majority of them, good and bad, are done at shorter-than-recommended OCI.quote:
Originally posted by Spector:
After all these months of comments and RedLine rhetoric one can come to the conclusion that regardless of the oil when One gets a poor UOA it is always the engine and something is not functioning properly somewhere. It is never the oil. In the case of redline, there is always a reason and it is never the oil. Terry, perhaps if you defended other oils in the same manner and said that there were engine issues as wll but it seems it only occurs with Redline. Has anyone every seen a poor UOA with redline where a problem did not exist in the engine, the oil just wore out or could not do the job??????????
