Latest UOA from my 2003 330Ci BMW Diff. Same ring and pinion, new Quaife LS torsen type carrier. Used the same Red line 75w-90 NS without the limited slip additive as suggested by Quaife.
Two track days, Watkins Glen and Road Atlanta and about 6 or 7 AutoX events. About the same use as the other OUAs.
Code:
Make / Model 2003 BMW 330Ci
engine M54
diff type open open Quaife
Total miles 38,000 53,400 81,000
Brand Castrol? Motul Red Line
Weight 75w-90 75w-90 75w-90 NS
miles on sample 38,000 15,400 27,600
#changes factory fill 2nd change
type SAF-XO?? Gear 300
date 8/5/2006 5/28/2008 01/15/2010
Aluminum 0 1 2
chrom 1 2 2
iron 240 197 190
copper 2 1 1
lead 0 0 1
tin 3 0 0
moly 0 0 0
nickel 0 0 1
manganese 10 6 6
silver 0 0 0
titanium 0 0 0
potassium 1 1 4
boron 216 441 226
silicon 7 19 82
sodium 4 3 10
calcium 7 14 14
magnesium 3 1024 14
phosphorus 1452 1587 1939
zinc 6 6 10
barium 3 0 30
viscosity SUS @ 212 F 74.5 71.1 72.0
viscosity cSt @100C 14.12 13.23 13.47
flashpoint*f 410 395 415
water % 0 0 0
insolubles % 0.1 0.3 0.3
Blackstone comments:
This oil's viscosity measured correctly for a 75W/90-grade differential lube. The main reason for
the high silicon in this sample is due to the silicone lubes and sealers that were used when you installed the
new Quaife torsen-type limited slip unit. All wear metals were steady compared to the previous sample even
thought you ran this oil a lot longer. That means this differential is wearing very well and no mechanical
problems were developing at 81,000 miles. No moisture was found and insolubles were low. Look for even
better results at the next oil change.
Code:
engine M54
Aluminum 0 1 2
chrom 1 2 2
iron 240 197 190
copper 2 1 1
lead 0 0 1
tin 3 0 0
moly 0 0 0
nickel 0 0 1
manganese 10 6 6
silver 0 0 0
titanium 0 0 0
potassium 1 1 4
boron 216 441 226
silicon 7 19 82
sodium 4 3 10
calcium 7 14 14
magnesium 3 1024 14
zinc 6 6 10
barium 3 0 30
water % 0 0 0
