don't use a non-detergent oil in that motor! if you want to use a 30 weight hd oil fine, or maybe a 15-40 fleet type. yes, i beleive that if you have an extra qt of redline and you really want to use it in your 10hp, it would be fine as well. i doubt that the extra detergency of the synthetic, seeing that yout motor is also filterless, would cause a major chunk of anything to come undone and destroy your motor. synthetics will, slowly remove some but not all, petroleum based oil sludge and varnish over time. they are a superior lubricant that many on this forum use in their own lawn and garden equipment. cooler running engines, better fuel economy, extended drain intervals, less friction, won't leave sludge, the list goes on. penz
