Just to let you in on a little-known fact: In many legal jurisdictions a driver SHALL yield to a yellow light the same as a red IF it is appropriate to do so. That is usually interpreted by the courts to cover those circumstances where a driver actually acellerates to get through the light. If you see the light go yellow then you are obligated to stop if you have not yet entered the intersection.
Of course the problem comes from the idiot on your &rse who sees the yellow and nails the throttle when you are going for the brake...
But that is a situation that cannot be helped by the first driver: He is going to drive prudently and slow to a stop. He will be focussing on his driving and not likely monitoring the following distance of every person that is behind him. The following driver must maintain a safe following distance from you and SHALL be able to stop his vehicle without striking your at all times. That's HIS responsibility. Of course that becomes an academic point in the case of being followed by a loaded semi...! But, if I am confronted with a yellow light, in most situations I stop for the coming red as I am supposed to do - my speed is usually in line with the speed limit so it is 'do-able'. I would rather do that than possibly run the light. If I found a particular timing problem with a set of lights I wouldn't hesitate to make an inquiry with whatever jurisdiction looks after same.
On a side note, I ride motorcycles and have had to inquire about the light sensors for certain sets of lights. I have always been listened to and have always had the problem adressed.
I wish that we had light cameras here...
John.
John.
