Recommended HVAC capacitor brand?
SEC Country
Does anyone have a brand that they recommend for HVAC capacitors? Something that you tossed in your outdoor unit and ran for the life of the unit, or at least a very log time?
I'd like to buy a replacement for when I need it. I have the tools to test them and the electrical knowledge to be safe about it.
This post is timely. Our forecast for the week looks pretty hot, so I washed out the coils on our outdoor unit on Saturday. It is now 23 years old, and the cap is original. It made me think I really should have a spare on hand!
No particular order whichever is available.
Genteq
AMRAD
TITAN HD
JARD
Just make sure you get a 440/370v. you can use a 440 in place of a 370 but not the opposite. 440 are rated as heavy duty.
yes sir. A spare cap, contactor and transformer can save lots of aggravation and money. even a few 3A standard blade automotive fuses.
Don't forget a spare power contactor, make sure you have the right amp rating or higher. Also the correct coil voltage and correct current AC or DC.
I’ve been known to keep a couple cartridge fuses for the disconnect on hand too-they will occasionally fail for no apparent reason, age more than likely.
The advice to have a spare capacitor and contactor on hand seems like good advice. I had to replace the cap in my condenser unit 2 years ago this July, on a very hot Saturday. Fortunately, I found a local hardware store that stocks capacitors, and was able to get the unit up and running.
Following the advice on brands, I was looking at AmRad caps, and noticed the CPT version, to protect from hard start damage. How do I know if my condenser unit is a hard start unit?
i think some Goodman units with txv valves have a relay and additional cap usually black in color that would be a hard start kit the cap you may be speaking of has the extra terminal which i think acts as a shunt if the potential relay part of the hard start kit fails.
hard start kits could also be installed on aging compressors that are sort of on their last leg sounds counterintuitive but often done in the trade also if there is low voltage issues or extended refrigerant lines are installed.
