Originally Posted By: jahwarrior1423
I have a 2015 Nissan Versa 1.6L V4 with 400+ miles now. I've been reading a lot about oils this past week but am still unsure which to go with. Car recommends 5w30 and OCI at 7,5k miles. Car is under warranty. You guys made a good point not to get EP oils since I'll be forced to change the oil before then because of the warranty that I have. The oils I see being recommended over and over is Mobil 1 Extended Performance and Pennzoil Ultra. But nothing in the area of oil I'm needing for shorter OCI. I began looking at Amsoil 5w30 XL but it seems to not get much respect from you guys because there isn't much data given from Amsoil.
With your guys expertise in oils, what would you recommend for a commuter car like mine that needs to follow a 7,5k OCI?
In reality, I'll probably change at 5k because most of those miles are high RPMs from highway driving.
Amsoil isn't too hard to get in my area. Priced around $7.80 for XL.
Or would using a EP oil be beneficial since most of the miles driven are high RPMs and change at 7,5k?
Since you're considering Amsoil and a 5k interval, have a look at the OE. With preferred customer pricing [yes detractors, insert discussion about MLM and membership fees etc here] you should be able to get OE for $4.40 a quart. It will easily do 5k and with your highway driving might go 7500 without a problem (but I'd get a used oil analysis to be sure on that)
