Originally Posted By: DNVDMAX
Deep,
I have a 2012 Versa S, M/T, manual everything. It is very crude but reliable. I have pushed it hard on Texas highways in 100+ degree weather where the posted speed limit is 80 and 85 on TX-130. It too has the HR16DE engine and it is buzzy. That was probably the easy part of its life. Now it gets very short trips and sometimes in extremely cold weather down to -41F.
The odometer just rolled over 43,000 and it seems to be getting a little more fuel efficient. I take the car everywhere for day fishing trips, hikes, scouting trips for my next hunt, and even up the Arctic Circle up to Atigun Pass on the Dalton Hwy. It doesn't skip a beat. Some climbs are in 3rd gear with the engine at full tilt. So far no oil consumption. I even rolled the dice and put 5W-20 this time around. I will get that UOA'd also to look for excessive wear from using a non recommended grade.
The car gets whatever lube is on sale. It has had Mobil 1 Advanced Fuel Economy 0w-30, Havoline 5w30, Valvoline NextGen 5w30, Mobil 1 10w30, Kendall 5w30, G-OIL 5w30, and now Mobil 1 Extended Performance 5w20. Yours will be fine as long as you change it per the manual.
By the way mine has the 3qt sump capacity with 7500/3750(severe) recommended OCIs per the OM.
Here is my first UOA with Kendall Semi-Synthetic 5w30.
HR16DE UOA
That is the hr16de I know! My 09 did numerous cross country trips, multiple mountain ranges, everything. It has also seen -30 in NY and 114 in AZ!
Thanks for the reassurance
