Recommend 1/4" torque wrench
D60
Colo
I'd like to replace my current 1/4" inch-lb tw. Presently I have a CDI 1501MRPH, and I need something still in the range of 20-150 in lbs. If it went lower than 20 or higher than 150, great.
Complaints: coarse tooth and I ALWAYS hit the limp, loose reversing switch in use.
So what I'd prefer:
-higher tooth count
-more recessed or more positive reversing lever
-probably NOT digital but I'd consider digital
-flex head a bonus but not required
-clicker of some fashion (not an old school beam, I have those, too)
Anyone have suggestions?
I have a Lexivon 1/4" torque wrench that does a fine job for my light tasks. Got it from Amazon.
I been using the Suzume 1/4" torque wrench 20-220 in. Lb off amazon for about a year, so far I like it. Scale is easy to read. The scale was very hard to read on my previous 1/4"
I have a 10-50 inch pounds snapon click and a 50-250 inch pounds snapon click as well as a 1/4 inch techangle. These days I usually use the techangle.
I'm lucky to have a 1/4" Snap On Techangle at work. It's really nice on low torque fasteners because you can see the advancing torque just like an old style dial torque wrench. But man, the Snap On price tag is outrageous for occasional shadetree mechanic use.
There must be reasonably priced electronic wrenches now.
Modern high tech beam or dial. The rest fall short of being able to do certain jobs correctly, as holding a torque is required for proper fastener stretch. Connecting rod bolts and head bolts/studs come to mind.
Here is a story from the light aircraft world, where the pilot crashed a plane due to a click type torque wrench:
The culprit was the cylinder #1 connecting rod, which became disconnected from the crank when a bolt sheared, punching a couple of holes in the crankcase in the process. The reason the bolt failed is that it was not properly stretched, which takes minutes of torque held on the nut. When the bolt is not stretched, the cyclic loads fatigue the steel into failure. When it is stretched, the bolt never feels any more load than the stretch load.
In considering this, I might give it awhile and hope Icon releases a TechAngle fighter. I bought the 1/2" Icon flex digi angle for Subaru head bolts and don't really have any complaints.
In the meantime I can keep complaining about my 30T CDI (yay!)
Fasteners are not torqued in that manner in the automotive world. Anything that needs to be stretched is tightened in a torque plus angle method. Its exceedingly rare, though not unheard of, that there will be a wait period in a torque sequence but all that I have ever run across are wrench off and the second stage is a higher spec than the first stage.
Another vote for the Tekton TRQ21101 here. Its range is 10-150 in-lbs..... Useful for carbon fiber bikes where often the spec is for some number in-between 10 and 20 in-lbs and the more-common 20-150 wrenches are too much.
I am considering something like that as a stop-gap -- maybe even the Lexivon but maybe that's sketchy. It would at least get me away from the 30T head I have now, which honestly is annoying even for trans pan bolts. That said, I should probably just keep the ~$40-60 and put it toward a nice digi angle unit. I'll eventually wish I had one that was angle-capable.
I'm not really willing to pay Snappy retail but there are alternatives. It seems most of the Matco and MAC stuff is Eclatorq and depending upon numerous factors can be had for more reasonable money. And most go ~13 to 265 in lbs, close enough to SnapOn's latest-greatest for me. I have a TechAngle in 3/8" (pawn shop find at $300, although I've never checked calibration) that can easily take over at that point.
