Piston slap is not a lubrication issue......It is caused by the piston skirts being slightly collapsed, and expanding a bit when they warm up, keeping the piston from continuing to rock in the cylinder. Annoying, but not worth fixing, until something else makes you go into the motor (If ever).
They don't have to be collapsed, they just need to be loose fitting, like in the GM "slapper" engines, which made noise from the factory. Piston slap became an issue with the advent of shorter skirts and bulk-fit pistons. The "solution" was to coat the skirts, something Ford was doing and GM eventually did too.
I just assumed since it sounded like the motor did not always do this, that something changed. And some motors are known for piston skirts eventually losing close contact with the cylinder walls when cold, but expanding when hot.
Of interesting note: the coating on the pistons can eventually wear off, and then you hear the slap
Nothing needs to happen to the skirts for this to be the case, just enough miles/wear.
The Modular pistons, unlike their Windsor brethren, have very short skirts. AFAIK, they are not prone to deformity, but they, being of the bulk-fit variety, are, like the GM engines, prone to be loose(r) in the bores than the hand-fit engines, which also, coincidentally, had longer skirts, LOL! The coating on them usually works to keep them quiet (that's why it is there) but I don't know how much it takes to wear it off, may not be much
