This was indeed a big concern with the launch of the new ILSAC GF-4 requirement of 800 ppm max for phosphorus/ZDDP.quote:
If SM oil did not apply to 60's era engines, it would not meet previous API certifications.
Only after extensive preliminary Sequence IIIG testing, run with the GM 3.8L pushrod V6, did the ILSAC committee finally approve the new limit. The IIIG test is a 100 hr test at 150C (300+F) oil temperature and has a max cam/lifter wear spec of 60 um.
Yes, lower levels of ZDDP are a concern for GF-4/SM oils, as ZDDP used in SG/SH/SL formulations was a very cost effective anti-wear additive that worked exremely well at generating a protective skin at temps over 150F.
Current High Mileage oils, such as the Pennzoil & Havoline offerings, which are not part of the GF-4 grades, have stayed at the 1000 ppm SL level for Phos/ZDDP.
Clearly, a concern exists in the industry and I'll stick with my recommendation of SG/SH levles of ZDDP for an older engine designs and even for other applications such as Briggs, Kohler,Tecumseh, etc. outdoor equipment engines which have components exposed to sliding friction.
