Why liquid chlorine? Why not 1-3 bags of shock in powdered form? How do you chlorinate your pool or is it saltwater? I use a simple floater and 3" chlorine pucks. I'll never install a chlorinator again. Went through 3 before I learned my lesson.
possible, especially if it has not been cleaned well on a regular basisso it might be time to replace the media.
I wonder how much that would cost.possible, especially if it has not been cleaned well on a regular basis
"diver"
to check the drains........seems silly to me, you had a really deep deep end on your pool?
I use a half gallon a day of liquid chlorine. I may convert to salt at some point. The liquid only adds chlorine and a bit of salt. The pucks have CYA binding them which when continuously added to the pool raise the level so high that the chlorine becomes ineffective. Then you have to shock or fight the algae. I used a ton of pucks when using the puck chlorinator. My pool is in the sun all day and 30,000 gallons. Handling the liquid is a pain but ends with a great looking pool with no pool store visits.Why liquid chlorine? Why not 1-3 bags of shock in powdered form? How do you chlorinate your pool or is it saltwater? I use a simple floater and 3" chlorine pucks. I'll never install a chlorinator again. Went through 3 before I learned my lesson.
Good point about the CYA. I go through about a puck a week but the pool is about 11,000 gallons. By the time the CYA level starts to get up there, it's within 1-2 weeks of closing time early October so it's never an issue. I've never had an algae problem. I only shock after heavy rains cause overflow or ducks and birds use it as a toilet.I use a half gallon a day of liquid chlorine. I may convert to salt at some point. The liquid only adds chlorine and a bit of salt. The pucks have CYA binding them which when continuously added to the pool raise the level so high that the chlorine becomes ineffective. Then you have to shock or fight the algae. I used a ton of pucks when using the puck chlorinator. My pool is in the sun all day and 30,000 gallons. Handling the liquid is a pain but ends with a great looking pool with no pool store visits.
I load 8 or 9 pucks in the feeder if I’m going to be gone for a week or so and it uses most of them to keep the chlorine in check. The price of pucks is way up from what I remember too. With a shorter season and not a lot of chlorine demand you can get away with pucks, as you found out.Good point about the CYA. I go through about a puck a week but the pool is about 11,000 gallons. By the time the CYA level starts to get up there, it's within 1-2 weeks of closing time early October so it's never an issue. I've never had an algae problem. I only shock after heavy rains cause overflow or ducks and birds use it as a toilet.
Ours is 18 years old now and has been salt since day 1. The only chemicals I have ever added to the pool is shock when first taking the cover off in the spring.I get my liquid 12.5% chlorine at Menards if you have one. If the pool is green and water above 60 degrees it will take some gallons to get it cleared up. Troublefreepool is a great site. I bought a test kit and have had a crystal clear pool other than liquid chlorine, mjriatic acid and some cyanuric acid each year. Do one reading there and get a decent test kit. The pool stores aren’t your friend and my water is much better when when I had a pool service and I save a fortune.
Liquid chlorine is shock. In fact it’s way better and acts faster than the granulated shock because it doesn’t add CYA to the water.Ours is 18 years old now and has been salt since day 1. The only chemicals I have ever added to the pool is shock when first taking the cover off in the spring.
Have replaced the T-15 cell once.
"diver"
Or a snorkel mask and a garden hose and DIY.
I back washed it twice yesterday, and will do another round today.Make sure your filter is clean before you add the chlorine. Back flush it until the water is not dirty anymore, then add chlorine and let the filter do its job.
I'm going to focus on liquid rather than the tablets (except for vacations) to keep things simple. Pool chemistry is not a side hobby I want to learn but I have no choice now.Liquid chlorine is shock. In fact it’s way better and acts faster than the granulated shock because it doesn’t add CYA to the water.
All these shocks, treatments, algae outs etc. complicate more things than they solve for because they oftentimes throw off the chemical balance of the pool.
At 1 whole pound a year for me, I have not had any issues over the 18 years I've done it.Liquid chlorine is shock. In fact it’s way better and acts faster than the granulated shock because it doesn’t add CYA to the water.
I had a gallon of liquid and added a few scoops of shock. The pool went from a cloudy green to a cloudy blue overnight with the pump running. This is not a salt water pool. I'll add more liquid today and see what happens.Why liquid chlorine? Why not 1-3 bags of shock in powdered form? How do you chlorinate your pool or is it saltwater? I use a simple floater and 3" chlorine pucks. I'll never install a chlorinator again. Went through 3 before I learned my lesson.
I've lucked out with price. I found 40-50lb buckets on clearance at Sam's club or Costco. I got a 40lb bucket about a month ago at Costco on sale for $120. It used to be $80-$90 2 years ago.C
The risk with that is if your water level drops below your skimmers, the pump will cavitate and burn out.Back to the suction issue - I put a water hose inlet T’d into the suction for when it’s hard to prime - once the pump ramps up I close the 3/4” valve …
Made things allot simpler …
I have the bottom suction plugged bcs the Kreepy runs best like that …
Ran it like that for 25 years - we don’t run automatic cycles …The risk with that is if your water level drops below your skimmers, the pump will cavitate and burn out.
