I'm somehow attracted to cars that have anywhere from 150k to 300k miles.
Typically, 10w-30 is my cup of tea. I used to use Valvoline only, even Synpower only... but I have noticed that synthetic does seem to clean the dirt deposits around gaskets out fairly quickly.
Now, I'm after saving $$$, finding solutions to keep the oil inside my engine, and definitely not increasing wear to the motor. So... I'm wondering if 10w-30 dino is all that's needed for me. I'd say so, but I'm really looking for "simple advice that you'd tell your kids on your death bed", such as: (1) you want less VIIs, (2) it's all about the base stock, (3) it's all about PAO oil, (4) stick to dino only, (5) 5w-30 synthetic is thicker than all Xw-30 dinos, (6) if you are able to use synthetic without leaks, change filters at 3-5k miles & top off oil, then do complete oil change at 6-10k miles, (7) a quick fix for an engine which originally calls for 10w-30 starts leaking would be to add 10w-40 / 15w-40 / lucas / bars leaks [product # here]...
.... ETCETERA!!!
Where's the reasonable advice??
I'll admit that I don't truly understand how to find a good base stock, I don't TRULY understand how VIIs work, and I definitely don't know what PAO oil is, but I'd like to learn how to keep cheap cars running cheaply without overhauls and expensive work that is more than the cost of the vehicle.
Whole reason I've decided to finally register today is that my buddy's Suburban is leaking a good bit from the rear main seal. The bars leaks rear main seal stop leak has helped a bit, but I don't think it's completely stopped.
I also checked my Volvo when I heard the bearings were sounding a little DRY today, and a fresh quart I added just put it on the tip of the dipstick!! Last time I took it to Sears to do an oil change, and they said 5w-30 was all they offered in bulk. OK then... it leaked a bit, but I never let it get below the dipstick until recently. It's been a couple months since I last checked it, and I've been running it pretty hard for the past month or two, but at least I put that fresh quart of NexGen oil I got for free a while back (stopped the dry bearing sound within a few hundred feet, at least!), just to get me to another shop
to change my oil @ a Goodyear shop for $24 after tax because I had a coupon. I can't beat that price, but I'd at least have put in 10w-30 if I had done it myself.. which is what I wanted. They, too, only stock 5w-30. I think it's a conspiracy that shops only stock bulk oil in 5w-30 nowadays... but whatever. I watch the Goodyear LADY
take my filter off and compare it to the new filter. Both are Purolator filters, but the old one was maybe 60% the width of the new one. Apparently they were both threaded the same, but I find it strange that two different shops would have different recommended Purolator filters for my car. Very strange, and even tho Goodyear didn't do anything wrong (maybe Sears didn't do anything wrong, either, because multiple filters will work on my vehicle??).... but letting someone else change my oil, even for free labor and a quart of free windshield wiper fluid.. it just makes me a little nervous.
Soo... lesson learned, but how do I know I'm treating a high mileage engine properly or not??? Without paying folks for an oil analysis of my car, preferably. What are the "need to know" tips you'd tell your son or grandson in order to keeping his Volvo running to a million miles???
.... ETCETERA!!!
