edyvw
$50 site donor 2026
There you go.People like you clearly have a hard time reading. I already stated in my original post that if I have to use the OEM RDU fluid I will, and based on the replies here that's more than likely what I'll end up doing until a (trigger warning) higher quality compatible fluid is presented.
And you will never know what is going on in reality.
But take into consideration one thing.
At the beginning of 2000, when VW introduced the Borg/Warner Dual Clutch transmission, they had a fairly high failure rate. They used full synthetic, PAO, and ester-based fluids. The solution presented itself in a semi-synthetic fluid that Pentosin developed.
And no, those transmissions that guy talks about do not fail because of fluid. They fail because, well, they are just bad.
