Really dopey question re power supply
Champlain/Hudson Valley
Guys, I have a hp Envy (with the lesser of the two screens) and either the dog or the cat has chewed well into the 90 degree plug of the power supply.
I leave it plugged in and I'm sure it was a tempting treat to gnash on.
The transformer works OK
Are these plugs available?
I assume it's 2 wires and maybe a shield wrap.
Thanks
If you mean this piece - the answer is yes, flea bay and the like are a good place. But you need to measure both the outside diameter and the inside pin it fits into. The pin is the hard part. The good news is there is often at most 1 or 2 sizes of pins for each outside dieamter, and its usually pretty easy to eyeball the difference. Fore example - I got these 5.5 x 2.1mm plugs recently.
https://www.amazon.com/gp/product/B07C7VSRBG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
