I don't believe there's a vacuum advance block, at least not that I can see. The vacuum line comes off the port on the carb, goes into a tee, with one hose off the tee going to the vacuum advance can and the other going to the TVS on the front of the engine which then exits to the EGR valve.If you're running EGR then what's your vacuum advance?
When running EGR you're supposed to run a vacuum advance block.
Running EGR you normally block the vacuum advance from giving more than around 12 degrees of advance.
Again the reason they do this is NOx.
For the most fuel economy when running EGR run as much advance as the engine will allow.
Ideal EGR for fuel economy, ignoring NOx, is going to be somewhere between the recommended blocked off vacuum advance and full vacuum advance.
The block is just a plate that goes in the distributor that limits the advance you may not have it or need it.I don't believe there's a vacuum advance block, at least not that I can see. The vacuum line comes off the port on the carb, goes into a tee, with one hose off the tee going to the vacuum advance can and the other going to the TVS on the front of the engine which then exits to the EGR valve.
I changed that vacuum line from ported vacuum to manifold just now and the performance was MUCH improved! I'm now holding 22" of vacuum at idle. I re-tuned the idle screws and it's almost Lexus smooth at idle now. Now, here's my next question:
Should I be running the EGR valve/TVS off ported vacuum, and the distributor off of manifold vacuum? Or does the EGR system not care?
Edit: I believe the vacuum advance maxes out at 12° from the factory, which would put total timing at 36° under full advance currently. There's zero detonation that I can tell, running 87 octane.
With 12 degrees of vacuum advance you probably already have is distributor thats setup for EGR.
The EGR running on manifold vacuum will likely give you EGR at idle and will make you car run like poo, may stall when you step on the gas when in gear.
Ported vacuum gives little to no vacuum at idle, gives vacuum at part throttle and when wide open throttle the vacuum is normally gone anyways so no EGR at WOT.
While I agree, there is more to it than just plugging into full manifold vacuum. Smoggers retarded advance at idle via ported vac advance to make the car run hotter, as you said. But they also increased base mechanical, for example from 4* to 12*.No do not use the "ported vacuum". The ported vacuum elimins or reduces the vacuum at idle, for lower NOx emissions.
Just try it ported vs manifold vacuum at idle. You will likely find it runs much better with manifold vacuum. With full manifold vacuum it engages the vacuum advance at idle.
Big plus one on that. My buddy never could get his 65 Mustang to run right until I welded up the slot in the advance bar to limit the amount of total mechanical advance and we played with the springs a bit so we could increase the base timing while keeping total advance at a safe level.While I agree, there is more to it than just plugging into full manifold vacuum. Smoggers retarded advance at idle via ported vac advance to make the car run hotter, as you said. But they also increased base mechanical, for example from 4* to 12*.
The biggest problem I've had with my iron headded 60's cars is too much vacuum advance causing pinging with crappy CA wannabe "Premium" 91* octane.
Plus, today's gas is different. That distributor might need a full recurve to attain optima results. I would try to manage the lean surge...
But as others have posted, those plugs look pretty good! He ain't far off at all.
Well done. Welded advance slots for the win!Big plus one on that. My buddy never could get his 65 Mustang to run right until I welded up the slot in the advance bar to limit the amount of total mechanical advance and we played with the springs a bit so we could increase the base timing while keeping total advance at a safe level.
If the EGR wasn't working, and your distributor is working (with the proper advance) it would be pinging like crazy. You need a great deal more advance with EGR than you do without. That 38 degrees (mechanical and vacuum) that you came up with sounds about right for a 1979 smog engine with GM HEI and EGRThank you for all the help, everyone! I cancelled the calibration kit for now; after lubing the advance weights, switching the distributor to manifold vacuum, and retuning the idle circuits and speed I must say the car has never run better.
I need to grab a couple feet of vacuum line so I can clean things up and get the EGR hooked back to ported vacuum per the diagram in the service manual. I'm not sure the EGR system is working, but it is in place, so I'll do some more investigating there.
Gotcha. No pinging that I can detect, so I must be good!If the EGR wasn't working, and your distributor is working (with the proper advance) it would be pinging like crazy. You need a great deal more advance with EGR than you do without. That 38 degrees (mechanical and vacuum) that you came up with sounds about right for a 1979 smog engine with GM HEI and EGR
Lean mixtures burn more slowly. Idle mixtures are lean; they need more lead.So glad this made such a difference!
The whole deal with ported vs. manifold advance is something I wish I understood the "why" of a bit better.
As has been mentioned, the early smoggers used less lead to make the mixture burn hotter. Thermostats went from 180* to 195* in many cases.
Low load (throttle blades closed) is high vacuum. Vacuum advance adds lead. Rich mixtures (throttle blades open) need less lead.
So vacuum advance is used to enhance mechanical advance.
I really like working on cars from the seventies. I never did get the tuning or timing coordination between EGR and ignition advance.I found some extra vacuum hose on the garage and got everything re-routed and correctly plumbed. I also verified that the EGR system is working correctly, both the valve itself and the TVS that controls it.
I pulled the #2 plug again and looked further down the insulator, as was mentioned earlier. It was a nice, off-white just bordering on grey so I think I'm going to leave the fueling alone for now. I did bump the accelerator pump over to the closest hole, I was still getting just a bit of a lull on low speed tip-in before she caught her breath and took off.
Did you pull the carb jets and make sure that they are clean, and jetted correctly? They don't look bad. I added a link to compare. Hemmings also has a spark plug chart.View attachment 232411View attachment 232412
I'm doing my best to learn the world of carburators, so bear with me. These plugs came out of our newly acquired 1979 Cadillac Deville with a freshly rebuilt, bone stock 425 that's fed by an Edelbrock 1406 carb.
From what I've read, the 1406 is a 600 CFM "economy" minded carb, which should be just fine sitting atop a low-comp smog-era 425. While I admit the car runs good, it has a light surge at steady cruise that I'm working on diagnosing.
My process so far:
Verified spark timing per the service manual: 23° BTDC @ 1400 RPM with the mechanical advance vacuum line removed and plugged. I'm sitting just above, maybe 24-25°. The cap, rotor, plugs and wires have less than 3k miles on them, and I verified that they're in good shape. I did find the mechanical advance weights to be very sticky, but a little brake clean and a light spray of WD-40 freed them right up. The current plugs are Champion 3031's, but I've got a set of AC Delco 41-819 double plat's on the way (more my own preference, Champions don't belong in a GM). They're gapped at the correct .060".
I replaced the upper and lower carb gaskets with the kit from Edelbrock, the ones on the car looked terrible and didn't match the ports on the adapter or intake. This helped a decent amount, I'm pretty sure there was a vacuum leak between the adapter and the manifold.
I pulled the metering rods and springs out of the primary circuit and found that someone has installed the "silver" springs which are the most stiff at 8" of mercury. The metering rods are the stock 7547's. I didn't remember to peek down at the jets, but I have to assume they're original spec as well. I have the Edelbrock carb calibration kit for the 1406 on the way, so I'll soon have the ability to play around with these parts.
I set the idle circuits with a tach and a vacuum gauge the best I could. I've got a solid 20" of vacuum at a rock steady 650 RPM in gear, which ended up being ~2.5 turns out on each idle screw.
Here's my initial thought: after reading through the manual and looking at the calibration chart, I'm thinking of going with 7342 metering rods and dropping down one size on the metering springs. This bumps the fuel up 1.5 stages rich on both the cruise and power circuits.
Given the condition of the plugs currently, do the bigger brains in the room agree with this assessment? I'm completely open to whatever tips and tricks you all can share with me.
