I think this makes sense. It seems to me this way the fluid that is most likely to need replacing is bled out of the caliper. It's gotten the hottest, and water is heavier than brake fluid so moisture should be in the caliper.I always crack open the bleeder before pushing back the piston.
Then I thoroughly bleed the system with 2 liters of fluid.
