dnewton3
Staff member
I disagree; it's not a "design flaw". It was a design choice.It’s a design flaw. I don’t have a premise. If I owned this vehicle I’d start with shorter oci’s at 80k and strain the oil to see if the belt is shedding. It’s not the oils fault. I’d also change the belt before 100k or sell the car.
It's not the only engine to use a wet-bath timing belt. For example the new little Dmax diesel from GM also has a wet-bath belt that has a claimed 150k mile life, but the engineer in the video interview hinted that it could go much futher than that. Perhaps they will also have "debris" clog the pick-up tube? Don't know; engine's too young to have a history yet.
I don't particularly like intermal belts; makes changes much more difficult for the DIYer. But then again, one of my fav engines (Ford 3.5L n/a "Cyclone") has an internal water pump. It also is not the only engine to have such a pump. I don't like the internal water pump, but the rest of the engine is spectacular and I just accept that some day, if I own it long enough, it will be a big expense for me to cover. That, too, was a "design choice" and not a flaw.
Often, packaging issues lead OEMs to make choices; they have to make compromises based on a large set of criteria. Sometimes a design emerges that may not be optimal to the end user, but it achieves the task and serves well, despite the cursing that goes on when it comes to maintaining the item.
I'm as guilty as others when loosely throwing words around at times. But this is a particularly specific topic here. The internal belt isn't a "flaw". It was a choice to accommodate other items which had higher priority.
