I use the strongest magnets I can find on my oil plug and mounted on the oil filter. The stronger they are the better the mag field can penetrate the can and extend farther into the oil itself. I mount them with like poles together as the repulsion would also help push the fields into the oil. The more magnets and the stronger they are, the better they work. I've been using them for 13 years w/o a single problem. Every time I've cut a used oil filter open there have been piles of metal stuck to the can by the magnets.
