Originally Posted By: Dwight_Frye
Originally Posted By: bigjl
I use axle stands and a jack most of the time. I don't have a drive just a parking space by my garage otherwise I would use ramps, with something permanently in the ground to stop the ramps sliding when driving up.
I should perhaps look into buying better ramps to stop that.
If the car is going to be in the air for more than an oil change i will put the ramps up in the car park space by my rear fence as then I can wedge the ramps against a small kerb.
I had a problem with the ramps sliding on a slick concrete garage floor. I bought the cheapest, ugliest rubber backed bath mat that I could find, about 48" long. I slit it in half lengthwise and put a section under each ramp, rubber side down. It works perfectly to keep the ramp in place when driving up it. I also make sure to wedge the ramps under the tire with a few kicks before I start the drive up them.
Had this same problem too. There is definitely a trick to driving onto them. My two previous cars were AWD which made it even more difficult.
