Originally Posted By: supton
...11% is close-ish to half a gear, so perhaps it just optimizes the system that much better.
And it's the whole system that matters. I'm not an automotive expert as my major is in electo-mechanics. With electric motors you don't have to worry about RPM for making torque. So when designing a system you can pretty much work off of the tables with HP, TQ numbers and optimal RPM.
Gas engines are totally different. You have to consider bearing loads, lower RPM means more load on the bottom end, pre-ignition, combustion efficiency, temperatures etc. They all change with RPM and for gasoline engines in general, raising the RPM solves a lot of these issues.
