Originally Posted by IndyIan
https://www.ramforumz.com/threads/3-55s-vs-3-92s-with-8-spd.146873/
I'm very surprised to see the top gear ratio is the same on the 6 and 8 speed, seems crazy the 8spd is that much more fuel efficient.
3.92 puts the final drive ratio about the same as my Outback, which pushes much less air but hasn't got a whole lot of torque at 1500rpm either. I think with the 8spd there's not a whole lot of reasons to go with the 3.92 unless you are towing heavy alot. I'm pretty sure my Dad's 2018 6spd has got the 3.21 and unloaded it does 60 mph quite happily in top gear. Its not like the engine sounds terrible if it downshifts either, so I'd rather get good mileage most of the time and then have the odd downshift.
This is a little off topic......The 1500 Ram never actually used a true 6 speed! It's still the same 545RFE with Two 2nd gear ratios. FCA just renamed it 65RFE for marketing reasons as GM & Ford had true 6 speeds. It never uses the 1.50 & 1.67 ratios in succession.
