Originally Posted by OVERKILL
Ahhh, OK, so you had the VCT 360HP/390TQ version mated to the venerable 5spd NAG-1. I would expect the Pentastar mated to the NAG-1 to feel even less frisky given it gives up 130lb-ft and makes it 550RPM later.
The 8spd has really done wonders for both it and the HEMI really. Even our little EcoDiesel feels reasonably quick mated to it.
This is the dyno graph for a stock 390HP HEMI:
As you can see, it makes more torque at just over 1,000RPM than the Pentastar makes peak.
Nope, had the 545RFE, 2012 and 2013 had the 65RFE which was basically the same transmission but you could use all 6 forward gears when using electronic range select vs 5. V6 models got the NAG1 for whatever reason, I feel like the NAG1 was geared better, less spread between 1st and 2nd.
I saw that graph, at least to my butt dyno the 5.7's power comes on like a surge, where the v6 feels like it'll give it all the second you put your foot down. The 2016 Charger R/T was like that as well, but not nearly as bad as my Durango was, the 8 speed is better at keeping it in its power band. A tuned 5.7 though feels WAAAAYYYYYY better though, but that's more apples to oranges.
Oh that's funky, I would have expected the NAG-1, given the 6.4L in my Charger was backed by it
Wonder if it was transfer case related?
Perhaps it's the HP curves that you are feeling the difference in? The HEMI obviously makes a ton of torque, I'm thinking power delivery, which of course would hinge on VCT action, and is single-phase versus variable on intake/exhaust separately on the Pentastar, may be why it feels the way it does
We owned a 2016 Durango with the 3.6L and also test drove a 2017 with the 5.7L. The latter felt more ballsy everywhere, but both of them felt significantly less responsive than my 6.4L, which is of course also geared to the moon and I expect has significantly different throttle programming making direct comparisons like that somewhat silly. We felt the 3.6L worked really well for what it was; we were not unhappy with it, but my wife certainly likes the power of the HEMI better. She had a NAG-1 backed 5.7L in her 2006 Charger R/T before the Durango and missed it. She loves the torque of the EcoDiesel but hates the frequency of regens we are experiencing with it, which isn't uncommon with winter driving, and this is our first winter with it.
I didn't really think of all that lol... I could have easily been mistaken torque for power. Maybe I can convince my little brother to let me drive his Charger, same gearing similar weight just different engines
wish me luck on that one lol
