Radio antenna
Propflux01
$100 Site Donor 2026
Central Arkansastan
I have an older AM/FM radio set up that I use in a metal building with a standard shingle roof. problem is I have almost 0 reception from this radio or any other inside this metal building. what I'm wondering is how can I make this better. the radio only has one wire sticking out the back of it that you just tack up to a wall somewhere, that being said it is not a dual dipole type antenna set up for anything like that. What can I do or use to make this reception better, as i cannot even tune anything as the building for better reception because it so bad I can hardly hear even the strong stations? Any ideas?
With 1 wire for the back, sounds like that is for FM as a lot of radios have a ferrite bar inside for AM, which is directional.
Being in a metal shields reception. Best bet would be get outdoor antenna for FM, or experiment as much as the environment allows.
For am, if no external connection, may be tough. Do others have radio's they can bring in to see for one with better sensitivity?
My better AM radio's is a CCrane and GE Super Radio. My Sangean PR-D7 also does a good job.
Can you attach a wire and make the entire building an antenna?
As a kid , i used a 3 strand barb wire fence on 30 acres
as an antenna for a heathkit shortwave receiver. I had fantastic reception. ( I'm just lucky that lightning never ran in on it.)
What is the brand of radio and how many antenna connectors does it have?
That's..... AWESOME
It's a cheap 3-cd 2 cassette Emerson. I use it just to have some tunes in the shop while I work.
Your metal building is acting as a Faraday cage.
I would run what is know as a "longwire" antenna wire outside, a simple say 16 guage, insulated stranded wire. Make sure the far (free) end is insulated from any metal or ground.
Drill a hole through the metal with a grommet for the wire, then wrap it around the wire hanging off the radio.
And try to keep the wiring and radio away from any type of fluorescent light or any device that might create interference.
