Radiator Leak?
CA
2007 Honda Accord, 174K, original radiator.
Engine bay was degreased about a month ago. Since then, the following rust has developed on the radiator, but only where shown. Rest of the radiator does not have this rust.
I pressure tested the radiator for 1 hr and could not find any leaks or meaningful pressure drop.
Do I have a radiator leak?
That rusted part is a core support or crimp for the core seal on the radiator appears to be steel if it rusted.. It's not exposed to coolant and will not cause a leak.
That engine compartment looks sparkling clean for a 2007. Someone works hard to keep it clean? Probably corrosion from the caustic cleaner used?
Perhaps the rust is from the cleaner you used?
Since you have already pressure tested it and confirmed, I would just leave alone until it actually leaks.
