Just curious if any of you race in any faction, and what you use. I don't personally, but my friend has done amateur drag racing, short track racing and road racing for over forty years. I've worked with him on various projects, and through the years he has pretty much stuck to only three racing oils. I met him in 1982 at a local drag strip. He had an alcohol injected 68 Camaro with a big block 496 Chevy. He was a die hard Kendall GT1 user at that time, until the original formulation disappeared in the late nineties. He then switched to Pennzoil GT, and ran it up until around 2015, when he switched to Amsoil Dominator. He also started using 10w30 in many of his engines vs the 50wt he'd always used, although he still uses 15w50 in quite a few of his engines that have been built with large clearances.
So...what do you race and what do you use?
