natenkiki2004
Finally got it installed after going through several configurations and figuring out how best to route the lines. I did set it up as a bypass filter, not in-line with the heater core. Also used 2 ball valves that I can turn off in case something goes wrong with the filter housing or heater core.
Before anyone says anything, yes, the line on top of the filter IS the highest point in the cooling system so there might be an issue bleeding. However, I did a test run and ran the engine before opening the ball valves. I opened them as the engine was running to give the air a good push. The lines heated up quickly so I don't think it's a huge issue. Before I even started the engine, I squeezed several hoses to bleed air out by hand, seeing many bubbles come up to the radiator. After running the engine a while, I'm getting more bubbles into the reservoir, it seems to be bleeding nicely.
I had planned on keeping the lines low but after going through several plans on pipe routing, this was the best one I could come up with.
Here's pictures, naturally I painted everything Ford blue:
