I have been using Wix oil filters on my cars now for about 3 years with good results. As many of you know, their website seems to be VERY outdated as far as specs on the individual filters go. So I sent them the following questions:
They state that these are 19 micron filters? What does that mean. Do they catch all the particles bigger than 19 microns, half, 25%?????
I wrote them back asking, but haven't heard anything back yet. Just wanted to know if anyone had a clue?
Thank you,
Brian Miller
This is the reply I got back:quote:
I would like to know the current specs on the following oil filters: 51334 and 51348.
The 51334 is used on our Hyundai Santa Fe 2.7L V6, and the 51348 is used on our Saturn 1.9L 4-banger.quote:
51348:
3.404" high; 2.921" OD; 3/4-16 American thread; Contains media rated at 19
micron; Contains filter bypass valve set at 8-11 psid and an anti-drain
back valve; static burst pressure is 275 psi; flow rate is 7-9 gpm.
51334:
3.194" high; 3.252" OD; 20 x 1.5mm thread; Contains media rated at 19
back valve; static burst pressure is 280 psi; flow rate is 9-11 gpm.
Thank you for your inquiry and your continued interest in WIX Filtration
products.
Chris Greeson
Technical Service Representative
Thank you,
Brian Miller
