Originally Posted By: RWEST
Interestingly enough, for those concerned about ZDDP, as I certainly am, with a pile of flat-tappet cammed vehicles, when I had Blackstone do a VOA on the CI-4+/SL "T" 5-40, it came back showing less Zinc/Phosphorous than the used CH-4/SL stuff I'd also sent along.
The VOA numbers on the CI-4+/SL stuff is making me so nervous that I'm sending another sample of it to Blackstone to re-check.
Blackstone is becoming notorious for unbelieveably low numbers on their VOA tests. Do a search and see for yourself.
Frankly, I wouldn't worry about it, the recent Turbo Diesel Register comparison test showed quite healthy P/Zn numbers for CI-4+ Rotella 5w-40.
If you can't sleep without doing another VOA at least send it to a different lab, don't throw good money after bad with Blackstone.
