Maybe L-427 Kendall Super Blu
Multipurpose, Extreme Pressure Lithium Complex Grease; NLGI GC LB Certified
Kendall® L-427 Super Blu Grease is a high-quality, multipurpose, extreme pressure (EP) lithium complex grease developed to satisfy the severe lubrication requirements of heavily-loaded plain and rolling-element bearings operating at moderate to high temperatures. It is NLGI GC-LB certified for use as a multipurpose automotive wheel bearing and chassis lubricant.
L-427 Super Blu Grease is manufactured with high-quality paraffinic base oils thickened with a lithium complex soap. It contains an extreme pressure additive, a tackifier, and rust and oxidation inhibitors to provide excellent wear protection, excellent thermal stability at high temperatures, and excellent resistance to corrosion and water washout. It forms an effective seal to help minimize bearing contamination and provides a high level of adhesion to the bearing surface for improved retention, reduced leakage and enhanced resistance to water washout.
