Originally Posted By: Craig in Canada
Chris B:
I haven't been around BITOG in a while but a couple of comments:
On the filler cap area: as others have said there isn't a lot of circulation there and deposits are probably from vapour and condensation. I wouldn't expect ARX to make this area spotless. Honestly, you might as well mechanically clean this area (fancy way of saying "wipe") as you won't be able to use it as a benchmark.
On the oil filter housing varnish. ARX isn't geared towards varnish. Lots of BITOG ARX threads have discussed this in the past, but I can't say that I noticed it pointed out in your thread. LC20 is supposed to be better at varnish, so is brake cleaner
It'll probably take a while to clear the varnish look from everywhere, and ARX may or may not be the best product to do it with.
On filter loading, ARX is geared towards sludge and carbon. Your pictures look like that is gooey sludge. IN theory ARX should dissolve this and it wouldn't load your filter if it was in solution. I believe someone commented on high insolubles in your UOA. As long as your air filter is working, this may tell you that something is going on. Grit and other gunk smaller than can be captured by your oil filter is in circulation.
I've seen a lot of discussion about doing short intervals on your oil filter. Since you have a cartridge type, it's easy to inspect and change. Make sure that you're getting filters from a quality OE source, but not the dealer. You'll save a ton of money going to someone like autohausaz.com and getting the same product for less. I would check your filter frequently for any buildup which seems to reduce flow. If you don't see any, leave it.
It's hard to determine what's effective and where you stand without a good measurement to guide you. The oil filter housing is only varnish, which is going to be slow, and the oil filler cap isn't going to see good flow. You may need to start pulling valve covers to see what's really going on. I don't know if you're comfortable with that, or how big a deal it really is on your engine.
Thanks for your input! I may see if I can borrow a scope and drop it in to see what is going on.
