I sent Lucas the following question: I'm interested in Lucas HD Oil Stablizer. I'd like to know how the MPG can increase when this will thicken the oil? Todays oils are thinner to get more MPGs.
Got this answer:Lucas Heavy Duty Oil Stabilizer will increase your oil's viscosity but it also increases film strength and lubricity. Film strength gives rings a better seal and
more positive lubrication. The oil is stronger in terms of film strength but slicker at the same time. The greatest benefit is reduction in friction, wear and heat generated from friction. Results are more easily measured in terms of extended drain intervals and longer engine life. Dyno testing in the past has revealed an increase of 1hp in racing applications and this is a very rare result of just a change in
lubrication.
Thoughts?
lubrication.
Thoughts?
