question convert-Torque bolts to 43 - 78 inch-lbs.
US
I don't have a torque wrench. It says Torque bolts to 43 - 78 inch-lbs.
Can anyone give a clue in pounds or general?
Thanks
Originally Posted By: Doog
E=MC2 x [R12.764563 /89.23745+(46635*657473)]x12 or divide by 12
Ah geez...you left out [649.8620*2.9999999]+27....other than that...it figures.
Seems to me rather a large range there in torque values that are specified. But what do I know...
This is barely more than finger tight. Most torque wrenches don't go lower than 10. I have a 5 -50 lb. model and like it a lot.
Originally Posted By: tig1
Here's a chart.
http://www.convertunits.com/from/inch+lbs/to/foot+lbs
Rather interesting how many places past the decimal point the conversions are taken too.
Also note at the bottom 1 ft. lb. does NOT equal exactly 12 inch lbs.. "How many inch lbs in 1 foot lbs? The answer is 12.0000000048."
I've been torqueing my fasteners wrong for the past 40 years.
when something is spec'd in inch-pounds and is less than 100, it generally means it will over tighten and strip real easy.
and you would need an inch-pound torque wrench for it to be accurate. a 3/8 torque wrench in foot pounds generally has 5 or 10 as the lowest number, and most all tq wrenches are not accurate at the lowest and highest parts of their adjustment scale.
+1 well said
Anybody who laughed at the "MPH blonde" but did not at this question, please raise your hand :-)
Clark,
Record your question on a video camera and post it on the youtube and wait until it goes viral. You will be famous and will get on the TV. Definitely, GoodMorningAmerica would be after you.
