Originally Posted By: motor_oil_madman
Why would you want one? I got one on my truck and it never budged even after 45,000 miles. Eventually the yellow rubber button cap fell off and I replaced the entire airbox lid with one from an 08 model cause they did away with the filter minder. Imo it's just one more thing to cause an air leak whenever that rubber oring rots out. Air filters are only like 15 dollars. Just change it every 30,000 miles or so and don't worry about it.
That's one of the silliest statement I've heard here in a long time.
Unless it was defective from the start, it didn't budge because the air filter didn't generate enough restriction to trip the unit. Which means the filter was perfectly fine and not generating enough restriction to trip the gauge. And just because one until failed, doesn't mean they all, or even many, will. You didn't mention whether the restriction gauge was OE or after market and what brand it was. Filters can last a very long time in service and not get restricted. Sure you can do the no-brainer and replace 'em every 30K, or $45 in 90K miles, or you can only replace none, or one in that time by watching a restriction gauge.
To the OP:
I don't know for sure, but I remember being told that manufacturer of the Filter Minder makes the unit for Wix. Donaldson also makes one and there are others. I prefer the ones that have a scale rather than the green/red/yellow ones. I tested one of my Donaldson units with a hand vacuum pump and gauge it it was right on. I have gauges on all my vehicles now.
No particular issues in drilling the plastic. Usually the units have instructions on how big a hole to drill and, depending on the kit you order, they may have the grommets or hardware you need. It's an easy install. If you don't want a grommet, there are brass bulkhead fittings that will work.
