Hi All!
New here, been coming this site whenever I needed info ... not really a car guy but have some general questions about oil that I think I have correct but all of you know more about this than I ever will. I have used Mobile 1 a long time ago (1985) due to driving a lot of mileage. I know that synthetic oil flows when cold where conventional does not - 2 bottles of both in a car trunk back then told the story - really scientific! And the valve tapping disappeared within seconds with Mobile 1. I haven't used synthetic since then as most of the cars I've owned said in the book 4500-5000 miles and/or 6 months and time was usually the factor in changing the oil. We just traded my wife's car in because it needed a rear seal replaced and figured to not put the money into an 10 YO car with 111,000 miles on it as to what next may go wrong. So we buy a Certified 2016 Ford Edge with 6500 miles on it and it has an oil monitor which tells us when it is the correct time based on our driving habits - I'm not used to this as in the manual it says we can go up to 10,000 miles or 1 year between changes ... it may be time to use synthetic again.
Strictly speaking about Motorcraft oil/filters only because it seems that dealers do the oil change with tire rotation (The Works) for about $39 with synthetic blend (and at this point a $10 rebate so $29) which is about the same price as what Jiffy Lube charges for just the oil change. The manual specifies 5W-20 (Ford Spec WSS-M2C945-A), the car has their 3.5L V6 engine and takes about 6 quarts. The car is going to be a daily driver and used mainly for anytime there are longer distance drives which won't be many.
So here are my questions ...
Does all 5W-20 flow about the same at colder temps (20 F) whether it is synthetic blend compared to synthetic? My thinking is yes but based on my experience with Mobile 1 I'm not 100% sure my thinking is correct. Living in NJ I doubt the car will see many -35 degree days.
Would there be any benefit to thinking about full synthetic as I'm not looking to extend oil changes just protect the engine better? I don't want to void any warranties by extending past when the oil monitor says it's time. I guess if a full synthetic handles cold and heat better then there may be a benefit.
Assuming if there isn't a huge price difference in full synthetic and it would be better - is the Motorcraft synthetic worth it? I'm not going to be changing my own oil and if I can get "the Works" at a good price it should be much better than going to Jiffy Lube and getting whatever oil and filter they throw in.
Thanks for any and all info!
