Originally Posted By: spackard
You may also have wiring in your house called a multiwire branch circuit.
If you poke around enough you may find an outlet in another room with 166V measured from hot to ground.
There's a form of wiring, common in commercial but not that common in residential: a multiwire branch circuit, where 220V is used to feed two branch circuits. When the circuit gets an open neutral you can get a very high voltage on the branch that has the lowest draw and a low voltage on the branch that has the highest draw.
Your running the A/C for a week sounds like it was enough current to open it.
I had this symptom in an in-law's house, '50's construction, in So Cal. They had a refrigerator on one branch and a microwave oven on the other branch, and the microwave ovens kept burning out even though the only thing using electricity was the clock. On their third oven, they asked me to look at it.
I traced the branch back to where the multiwire branch began, in a box with a socket, to a wire nut with 4 conductors in it. They had separated enough to lift the neutral. Twisting the conductors back together and then fitting a new wire nut fixed it.
There was a nice powerpoint file I found back then illustrating the problem but Google isn't what it used to be. This is the best I could find:
http://code-elec.com/userimages/Lost Neutral.ppt
^ I like this idea. I was thinking, before you mentioned it, "sounds like California".
Also note stuff like computers and home electronics get by on 100-240 volts, so you might have some normal working stuff elsewhere that's getting off-power.
