I explained that.
How does your engine compensate for fuel system degradation over 100k miles? Clogging injectors and weakening fuel pump?
Now in closed loop ..everything is taken care of ..but what about open loop? Will a premapped fuel curve be correct for 100k with all the aforementioned degradations? Same injector pulse width at the same MAP level ...forever?
Nope. The O2 readings are recorded and that alters the premapped fuel curve. This is in speed/density systems anyway.
Open loop ..unless you're a highway king, can make the 02 sensor the ONLY thing that can make your fuel economy peak.
From that same link:
FUEL INJECTION CONTROL PROGRAMS
The PCM uses two programs to control fuel delivery through the injector.
Both programs' commands are represented by numbers on a scan tool.
0% is the mid-point or normal command. A (-X%) means fuel is being subtracted, a (+X%) means fuel is being added as compared to the normal fuel need.
A. Short-term fuel trim - a short term or "right now" fuel correction based on O2 sensor input. ( GM: Integrator or INT 128)
B. Long-term fuel trim - a long term or learned correction based on the short term command. It has 16 or more different cells for different engine load and speed combinations. Long-term fuel trim is the basic fuel program that can adapt to changes in operating conditions.
