Quality Valve stems
New Mexico
Have a lot of trailers with a lot of tires...I cover each tire and keep the weight off when not in use...I have a heavy Gen set That had new tire and stems 4 years ago...It gets hot and dry here...I move the gen set for the first time since new tires and had rotten stems...Tires not too bad....Any recommendations for heavy duty?..... Military Maybe ?" ..... where to go?....Charlie
Metal stems should be available from any tire shop that specialize in truck and off road equipment. I assume that you have rubber stems that are rotting. FWIW--Oldtommy
I will check...I guess I don't get around much...Never heard of them, but will check today...Charlie
