Thanks Gene.....which SOPUS products do you consider the 'best choices'....and which do you consider....'not so much'?
What are your thoughts on PP 5w30 in a 5w20 application?
I tend to prefer the PP 5W-20 to the 5W-30 in applications that can use it. Most of my engines have a lot of timing chain and the 5W-20 and 5W-30 come out of the crankcase at a similar viscosity. Why have the extra VII shearing with potentially more deposits? I have zero issue with PP 5W-20 in a Ford 3.7L DOHC V6.
If I was putting oil in a shear prone and diluting TGDI engine like the Ford 3.5 Ecoboost I would prefer QSUD 5W-30.
In my Supercharged Mustang for street use 10W-30 or 5W-30 work fine at the temps I see but it has a lot of timing chain and runs 0.81 Lambda (Equivalent to 11.9:1 AFR on straight gas) at full throttle so I would use QSUD 10W-30.
In a normally aspirated 392" Windsor in a Fox Body I would have no problem with PP 5W-30 for a street - strip oil without issue. The OHV Roller Cam Engines are easy on oil with minimal shearing. The same things that make it work as a fuel economy oil work on the strip but these engines tend to run a little warm on oil temp (without a cooler) on the street for 5W-20.
The 1400 bhp (It's cut way back we can't keep over 1100 hooked on a little tire at the top right now) Turbo Big Bore x Stroker DOHC Cobra Motor in the Mustang Cobra Drag Car currently has 5W-30 but really should be 0W-20 at the oil temps we are running but those bearing loadings scare me to death (Don't know why after looking at 0W-3 Pro Stock Bearings) and we can't use the power we have now. It currently has M1 in it but honestly PP would likely be a better choice in 5W-30.
I don't have enough experience with PPU or RGT to feel comfortable making a comment.
Honestly I'm more of a fly by the seat of the pants type. If it looks like it will work, I'll try it. Honestly I've gotten bit way less than I should have. So take that into consideration before you go using something based on my opinion.
