Originally Posted By: ltslimjim
So, a based on capacity size, the ppm from adding any where from about 1/2 a can will increase 100-200 if using a full can of MoS2, not bad if your oil started with low or no moly to begin with.
At less than $5 for a can, it's hard to argue the value of boosting moly any meaningful amount. Sure, it's not the super-duper amounts but it's effective if it can raise it 100 ppm at least.
Or simply substitute a quart of Toyota 0W-20 or one of the Idemitsu made 0W-20's and get a similar 150 - 200 ppm moly boost with the preferred organic variety. Plus improve the base oil chemistry and increase the VI about 15 points.
Ah, nice alternative. I like it!
what about this, though, from toyota:
The synthetic oil should now be available at all dealers and should very soon be available in bulk, which will reduce the costs for everyone. Genuine Toyota Motor Oil 0W-20 contains a Toyota specific additive package within it, making it not interchangeable with other synthetic oils of the same weight such as Mobil 1.
