Originally Posted By: Rand
you read randomly on the internet to use a certain grade of oil 15w50 instead of the recommended 5w30/straight 30wt.. then bought an even thicker grade...then filled it without checking the level.. then mowed 4x....decision process suspect.... were alcohol or drugs involved?
Also 2 quarts is 64oz of oil not 48.. it was severely overfilled.
1) Unhelpful
2) Rude
3) Correct about being overfilled
20W-50 is just fine for air cooled engines in hot climates, under stressful conditions.
The HTHS (high temp viscosity) of Castrol GTX 20W-50 is 3.7, other 20W-50 conventional oils are similar.
The HTHS of straight 30 is, you guessed it, 3.7 or so.
Remember, air cooled engines typically run hotter than liquid cooled engines and HTHS is an oil spec that matters for this application.
You picked an appropriate oil. You probably overfilled it.
1) Unhelpful
2) Rude
