Originally Posted By: ZeeOSix
Originally Posted By: chubbs1
There are ways to get that stuff off but you shouldn't have to do that, take 'em back, I wouldn't want that grit in my engine...that is why we use a filter. Sloppy.
True ... shouldn't have to clean them, and yes, it's sloppy work.
BUT ... chances are there will be some degree of over spray on most of them. I just learned to clean them up ... in the long run it's just simpler and less hassle. Takes about 5 min to do.
1) Remove the gasket from the groove.
2) Spay some carb cleaner on a Q-tip -
NOT on the filter.
3) Whip over areas of over spray.
4) Repeat 2) & 3) until clean to your satisfaction.
5) Install gasket back into groove.
Sending emails to Purolator can't hurt ... might make them consider changing their grippy surface material application process.
Or, buy WIX/NAPA GOLD instead
