I changed the oil in the lawn mower today, it is an '89 or '90 John Deere 185 with a Kawasaki 17hp single cylinder, it's about 500cc if I remember correctly.
I changed the oil last year after the start of the season, so this doesn't show the full year (and I know many recommend changing at the end of the season, I just never get to it until spring) but this is a minimum of 25 hours of use, maybe up to 50, I don't keep track. Either way is less than the manufacturer recommended OCI of 100 hours.
The filter is a Purolator L14477 and I had used Chevron Supreme 10W40. I can smell fuel in the oil but it doesn't seem to have thinned out much if at all.
I have five acres to keep up, when I mow it is a lot of mowing at slow speed since the ground is pretty rough. I don't keep track of hours spent, just change every year and call it good. This year I used Delo 15W40.
The ADBV was in good shape, there were no tears visible in the media, I wasn't able to pull the end caps off with normal pressure. This filter is way bigger than what the JD OEM filter is, but this fits just fine and I put another L14477 in today in it's place. I would imagine by looking at this that I could go two or three years on a filter without worry, but at $3.27 seems changing the filter every year is good insurance.
I had never cut open a filter before joining here, I like to see that things are shipshape.
