Purolater Red Can
South
Purchased a Purolator PBL10241 (red can) at Tractor Supply yesterday and was surprised to see a wire cage and red nitrile valve.
Are these still the scourge of BITOG? It’s going on a lawn tractor…
Reads more like the aforementioned red can L10241, and the red adbv would be silicone, now used on the L. Don't understand seeing a wire cage though. PBL, currently uses a polyer backing.
Either way, on a lawn mower especially, should be fine.
Silicon. Good to know. Thanks. It definitely has a wire cage. Ran my finger in the filter to confirm.
Yep. But I've never seen a fram tear in person. I have Purolator
Ok. So the downfall was because of the problems with filter media then. Won’t hurt my 18 year old Craftsman-Briggs. Probably could never change the oil and filter at this point and it wouldn’t matter anyway!
Have we even seen any torn Purolators in the last year or two? Seems like whatever the problem was kind of just went away.
Over the weekend after years of using only Ultra's I put on a Puro blue can on one of my Mazda's.
Is the cage possibly punched louvers? I have a couple Puro Reds from a recent Menards sale, and they have louvers & a red ADBV (but it doesn't appear to be silicone, looks more like red rubber). The Purolator tearing issue was worse a few years back, including fat Motorcraft filters (ESPECIALLY Motorcraft FL820S ones), but they "seem" to have improved somewhat lately. Definitely don't push them for long/multiple OCIs, though.
The internet coined the OCOD (Orange can of Death) because they viewed the use of a fiber end cap as inferior to metal endcaps, until the term Tear-o-lator was coined.
I saw a few PH16s in the day that would've been good for target practice, only had 50% of the media they needed. And the old Cummins issue. Both resolved these days.
A red can Puolator with wire backed media? Not believing that until photos show that's the case. More filter changes or a misconception?
Just because I was curious, I took a picture of a Red Classic & a blue Purolator One-
I left the photos big on purpose-both filters have louvers, the Purolator One on top clearly has a bright orange ADBV, the Red Classic on the bottom has a lighter red ADBV that I'm not convinced is silicone (someday I'll cut one & do the burn test). In case there was any question, no cage, just louvers (that appear to be open BTW).
