Hello forum.
I recently did the 610.000km oil change on my Saab 900 turbo 16. (I will share UOA when I get the results.) OCI was 9494km with Shell Helix Ultra 0w-30 AV-L; the filter in use was a Purflux LS 245. (Purflux has discontinued the LS245 in may and replaced it with LS188B.)
I wanted to try the Purflux for their ingenious zig-zag folding (which in theory allows for more media), and because I have seen some purflux filters that the adbv rubber is put under additional tension by some springy metal thing.
But behold! There is no ADBV on this filter! You can see that upper end cap and the ring/tube/whatever where the filter element meets the base plate are two seperate parts. But while this ring thing is springy in some online videos of other purflux filters, mine seems fairly rigid. I can force some play between it and the end plate, but only minimal and only with brute force. And above all, there is nothing - no rubber, plastic, whatever - that could be interpreted as an ADBV.
Am I missing something? Am I too stupid? Or did SoGeFi manufacture this line of filters without ADBV, or does mine just have a manufacturing defect?
More pictures to follow tomorrow.
![c3b6lundfilter.jpg](https://turboseize.files.wordpress.com/2017/03/c3b6lundfilter.jpg)
![imgp8873.jpg](https://turboseize.files.wordpress.com/2017/10/imgp8873.jpg)
![imgp8877.jpg](https://turboseize.files.wordpress.com/2017/10/imgp8877.jpg)
