Pump sprayer nozzles?
Hudson, NH
I’ve been using this pump sprayer for winter applications of salt away. Works good for that. I would also like to use it like a foam cannon on the undercarriage, if that’s possible. Are there any foaming spray nozzles I can get that fit this type of sprayer?
Not really. From what I can tell the nozzles are made a certain way and aren't interchangeable
well since a foam cannon is usually hooked to a pressure washer at least 1500psi or higher and that is what 50psi? so uh no.
There are pump sprayers that foam. IK is one brand.
Lumintrail iK Foam PRO 2 Pump Sprayer, Professional Spray Bottle for Automotive Cleaning, Detailing, and Industrial Cleaning, Bundle with a Keychain Light https://a.co/d/8jodLcP
